I seen a lot of posts on how to adjust the doors so they close better, but I can't find anything on adjusting the door, on here or in the manual. The doors are sagging bad enough they won't even come in contact with the stops they hit below them.
Is there anyway to adjust them so won't do this?
That might be part of the problem... I think the nets offer some support for the doors. Not much, but enough to keep you from springing the hinges if you put any weight on that door.
The doors are pretty easy to adjust. I usually start with loosening the allen head bolts on the hinge and getting the door up as far as possible there. Then the striker on the door can be loosened and it has a fair amount of adjustment.
I agree, the nets do help keep the door from dropping or sagging.
Many of the new ones I set up need some adjusting, but usually it's the striker too far up/forward and rubbing on the upper part of the opening in the latch.
