Brake pedal goes to the floor - Page 3 - Honda Pioneer Forum
post #21 of 67 Old 12-01-2013, 08:26 PM
Moose's Avatar
Originally Posted by PoolGuy444 View Post
I hope some of these other guys have the a arm guards. I just put them on this morning and noticed the brake pedal to the floor today. I haven't experienced this until today. Hopefully someone else could chime in
Mine was doing it prior to A-Arm Guards. Also I have always been going straight when the issue occurs
Moose
Why do people call you Moose? Cause calling me Elk sounded funny
The Convoy
2014 Honda 700-4 (Optimus)
2013 Jeep Grand Cherokee Trailhawk
2013 Polaris Outlaw 90 (Smokescreen) (kids)
2009 Suzuki King Quad 750 axi (Bulkhead)
2008 Kawasaki Ninja ZX14R
2008 Harley Davidson 1200 Nightster (hers)
2007 Dodge Charger Daytona R/T Sublime 781 of 1500
2006 Harley Davidson Night Train
Moose is offline
post #22 of 67 Old 12-05-2013, 08:51 AM Thread Starter
I have now hauled several loads of firewood and just trail ridding and have yet to have it happen again since I adjusted the a arm guards.
ryan4703 is offline
post #23 of 67 Old 12-05-2013, 11:57 AM
Quoted: 53 Post(s)
No brake issues here. No a arm guards either.
rmk700 is offline
post #24 of 67 Old 12-07-2013, 09:45 PM
Moose's Avatar
Had the brake issue again today. Mine doesn't go all the way to the floor as the title says. but it does travel a lot further without seeming to push any pressure to the calipers. Its making me think it is a master cylinder issue. Seems like a leak in the primary cylinder by the symptoms, but hard to explain why its so come and go. Prior to the incident, it was sitting out in around 0 degree temps.( I had driven it out earlier that day with no issues). I parking braked and went to eat lunch. about 30-40minutes later came out released the parking brake, drove down to pick up the mail ( no issues and I used the brakes). It wasn't until I was about 1/8 mile down my trail and I was coming up to a tight squeeze between some trees, that it did it. As I depressed my brakes to slow to fit. there was no resistence until about half way depressed, and then it had limited effect and I ended up bumping a tree edge with one of my tires.
I was going straight at the time and slowing from maybe 5-7mph. Then after that, the rest of the day, (4 more loads and another 3 miles on the machine and) nothing.
Just a major pain to diagnose since it happens so infrequently. Yes its still under warranty, but the closest dealer is 60miles one way and I currently dont have a trailer to haul it.
Moose
The Convoy
Moose is offline
post #25 of 67 Old 12-07-2013, 10:27 PM
rich450es's Avatar
Quoted: 12 Post(s)
i wonder if it only does it after the parking brake is used ????????? (parking brake bleeding down after sitting for awile with it on )
rich450es is offline
post #26 of 67 Old 12-07-2013, 11:01 PM
DG Rider's Avatar
Quoted: 82 Post(s)
I haven't looked, but i would bet the PB is a mechanical worm gear type setup.
EDIT: Yep..
http://www.hondapartshouse.com/oempa...-brake-caliper
DG Rider is offline
post #27 of 67 Old 12-08-2013, 07:22 PM
David's Avatar
DG Rider,
Thanks for the link.
Great spot to identify parts and assembly.
Fun Stuff:
2014 Honda Pioneer (Serial # 0015)
2008 Weeres Pontoon
2008 Damon Daybreak
2007 Can-Am 400HO Outlander
2015 Honda Gold Wing GL1800
2012 Skidoo Skandic
2011 Honda Fury
1970 BSA 650 Rocket
1961 series A+ wife
David is offline
post #28 of 67 Old 12-11-2013, 03:30 PM
Anyone else having the brake to the floor issue like I am. I first thought t was a arm guards when turning. But it happens to me constantly while I use it. It's not everytime I brake but it's 1 out of 5 times I use the brake. It doesn't matter if I've turned. Parking brake used or not. It will do it just from shifting from forward to reverse. The other day I was driving over some dirt we had just moved. So I was back and forth back and forth. And it constantly did it. It also makes a strange noise in the rear when the brake does work right. I think it may be pads breaking in to rear rotor? Possibly?
PoolGuy444 is offline
post #29 of 67 Old 12-11-2013, 03:49 PM
Have you tried wiggling the rear brake system components to see if possibly some bolts didn't get tightened? If either the disk or caliper has loose bolts it could be causing problems and should be easy to spot.
post #30 of 67 Old 12-11-2013, 03:50 PM
Moose's Avatar
do you still have the plastic oem covers on the front calipers?
If you do, I suggest you remove them, and make sure you have clearance to the calipers when turning. It looks like the A arm guards aren't fitting every machine with the proper clearance. If that is hitting the caliper, or binding against that plastic guard, the plastic guard my be pushing on the brake line where it connects to the caliper. That can cause primary (front brake) fade. Which would put the main load to your rear brake. increasing your pedal travel and more noise from the rear.
If none of that is the cause, I have another issue with my brakes. I have diagnosed it down to what I believe to be a master cylinder problem. I contacted my dealer about it, their tech agreed with my assessment. Sounds like they will be coming to pick my unit up, or driving one of their guys out here to repair it on the spot.
Moose
The Convoy
Moose is offline
