food plots - Honda Pioneer Forum
post #1 of 10 Old 02-24-2016, 08:16 AM Thread Starter
food plots
Has anyone used the Ground Hog deer food plot tiller? Just got a 700-2 and I'm thinking of getting some add on's. Any idea's or tips would be appreciated. We've got some property in northern Mich. that I want to start putting in some food plots this spring. I'm new to UTV's and if I can save some head aches so much the better. Thanks much. PM's welcome
cookie is offline
post #2 of 10 Old 02-24-2016, 11:23 AM
Quoted: 26 Post(s)
I wouldn't suggest it. At least not until you modify the receiver on the 700. These receivers are designed for loads that push down on the hitch NOT up. I read a one of the forums I read about someone ripping their receiver off using one of those, I personally have damaged mine by have the hitch get caught on rocks as the azz end drops off another rock.
allgm1 is offline
post #3 of 10 Old 02-24-2016, 01:56 PM
Rust
Sure looks like a lot of rust in tubing.
papap is offline
post #4 of 10 Old 02-24-2016, 04:27 PM
Quoted: 26 Post(s)
don't let little things like that bother you, I'm more concerned with the the ones that hold water
allgm1 is offline
post #5 of 10 Old 02-25-2016, 03:39 AM
I agree on the hitch being weak on upward pressure, the picture in the post above could be of my machine after I left a hitch with a 4 inch drop on and went through a steep ditch. Had moved my hauling trailer and just stupidly left the hitch in. Repaired it and have not had any issues pulling and yanking and using it at will.
Jimbo is offline
post #6 of 10 Old 02-25-2016, 05:49 AM Thread Starter
How are guys beefing the receivers up so that they do stand up to rugged use?
cookie is offline
post #7 of 10 Old 02-26-2016, 07:58 AM Thread Starter
How did you remedy the problem? How are guys beefing up their receivers?
cookie is offline
post #8 of 10 Old 02-26-2016, 08:54 AM
Quoted: 26 Post(s)
I haven't fixed mine yet, I just messed it up a few weeks ago.
allgm1 is offline
post #9 of 10 Old 08-20-2017, 01:31 PM
This is an old thread but I'll add to it anyway. Might help someone. I broke the welds on my receiver hitch on my 700-2. As others have said they don't tolerate upward force very well. What I found was the welds were pretty poor quality. When a weld separates between the weld metal and the parent material it indicates lack of fusion/a weld that went in too cold. I ground out the bad welds and rewelded the receiver tube. I used a 250 amp MIG welder so I had plenty of heat. I would not consider trying this repair with one of the 120V flux core welders. If you are going to do any welding on the frame disconnect the battery or better yet remove the computer. Stray welding currents can destroy the computer.
kmitchl is offline
post #10 of 10 Old 06-18-2019, 09:09 AM
hey have you tried Poulan Pro PPCRT17 foor me i prefer going with this tiller on my atv. here is short description of this Poulan Pro PPCRT17
Poulan Pro PPCRT17 happens to be among the greatest tillers molded that you can use o modify your food last so that you can have better yield. Fold plots need to have a fine soil which is professionally grounded to so that you can have even germination. Poulan Pro PPCRT17 is powered by 210 cc engine which gave the tines relatively high tines rotation speed of up to 190rpm read more here credits @farmtilling.
jeiy jeiy is offline
