Pioneer 700 Switch Plate Install - Honda Pioneer Forum
post #1 of 5 Old 05-15-2019, 11:38 PM Thread Starter
Recently I purchased a center dash Switch Plate for my 2018 - 700. Looked at a couple and purchased one from mystic1219 (on this site). He was the only one to advise leaving a blank spot in the plate to avoid a bracket under the dash. Makes the install much easier.
I drilled out the rivets on the existing plate, and used a heat gun to loosen the glue holding the plate. Was able to remove the old plate without damage.
After aligning the new plate, I used a metal scribe to mark the cut outs. Tried using my Roto-zip tool to make the cuts. The Roto-zip had way to much RPM for the light plastic and was out of control. I mounted the 1/8" Sabrecut Roto-zip bit into my variable speed drill. WOW ! did that make a difference. I was able to cut the rectangles out with no problems due to the slower speed. Very little file trimming was needed. Here are the tools used, excluding the heat gun.
This may not sound like much of a project, but for an "Old Fart" with one usable arm, it's a challenge!
Hope this might help someone else.
Outnback is offline
post #2 of 5 Old 05-21-2019, 05:33 PM
@Outnback A customer came in with his 1000 with a Honda heater installed (same switch as the 700) so I got a few pics of the Honda switch while he was here.
post #3 of 5 Old 05-21-2019, 09:10 PM Thread Starter
Thank You Sir. That's the info I needed.
Outnback is offline
post #4 of 5 Old 07-16-2019, 02:22 PM Thread Starter
Had to update the Switch Plate to include a second volt meter for the second battery.
Outnback is offline
post #5 of 5 Old 05-19-2020, 11:12 PM
Is Mystic1219 still building/selling switch plates for Pioneer 700? I did PM him with no response, yet. Does anyone have his e-mail address and or mailing address (or phone#)? Thanks Lizard
JimLizotte is offline
