Tie rod installation for dummies (myself included) - Honda Pioneer Forum
post #1 of 11 Old 07-26-2014, 03:01 PM Thread Starter
Here is my poor attempt at a write up. A big thanks to @Dick, @DG Rider, @toodeep, @realtreegrizzly, and @Holland for the helpful posts and getting me going in the right direction.
Before we start, I take no responsibility for anything you do to your machine. If you don't feel confident after reading this, take it to the dealer.
That being said, this is a pretty easy and straightforward process. The dealer wanted around $300 to do this. I have $33 in parts and an hour of my time. I could probably do it again in 30 minutes.
Jack up the front and take off the wheel. Its clear that the tie rod is bent badly.
Loosen the lock nut using a 19mm wrench
Remove the cotter pin and the ball joint nut using a 17mm wrench
Remove the ball joint by unscrewing it. I counted 17 full turns on mine.
Remove the small clip on the boot with a pair of pliers. The service manual says to cut the metal clamp. You can't see it in the picture but it is on the far end of the boot. A new one from Honda is $3. Slide the boot towards you.
I used a pair of channel locks to loosen and remove the tie rod. It should look like this
Notice the lock washer on the left. The tie rods come with new ones .
Install the lock washer, NOT on the tie rod.
Using channel locks, I tightened the tie rod back. Slide the boot back up. I tried for 20 minutes to use the new metal band to no avail. i decided a zip tie would suffice. Here is the band and part number for those smarter than me.
Reattach the small clamp on the end of the boot nearest you. Reinstall the lock nut.
Then rethread the ball joint. 17 full turns back on in my case
Reinstall the ball joint nut and cotter pin.
Moral of this story, don't let your sister drive your Pioneer. I hope this is helpful. I'll try to answer any questions as best I can.
PioneerAdmin and Dick like this.
Volnut is offline
post #2 of 11 Old 07-26-2014, 03:14 PM
Holland's Avatar
Quoted: 13 Post(s)
Glad
2014 Pioneer 700-4
2011 Rancher 420 AT
1996 TRX 90
Holland is offline
post #3 of 11 Old 07-26-2014, 03:17 PM
Holland's Avatar
Quoted: 13 Post(s)
Opps..
Glad we could help. If that band is what i think it is you can sometimes get by clamping it with a side cutter. Otherwise they make a special pliers for them. Pretty sure ive seen them at advance auto for around ten bucks. But the ziptie might hold. Nice writeup for others!
2014 Pioneer 700-4
2011 Rancher 420 AT
1996 TRX 90
Holland is offline
post #4 of 11 Old 07-26-2014, 03:30 PM Thread Starter
I figured there was a special tool used based on how it looked. I got frustrated and used the zip tie. I gave it a few good tugs and it didn't budge. I'll check it after I get some miles on it and see how its holding up.
Volnut is offline
post #5 of 11 Old 07-26-2014, 07:16 PM
That's a great write-up! You know if everyone just did one, imagine how many we would have..
post #6 of 11 Old 07-26-2014, 10:17 PM Thread Starter
Thank you. I was hesitant to do it. I figured the extra hassle of taking pics and the fact that I had never done it before but after all the good info I've gotten from this forum I figured it was the least I could do to give a little back.
Volnut is offline
post #7 of 11 Old 07-27-2014, 12:55 AM
DG Rider's Avatar
Quoted: 82 Post(s)
For some reason i thought you were changing the outer tie rod, hence the lock nut tip i gave. I was thinking " how the **** does somebody bend one of those...". This makes more sense.
This is the tool...
http://www.autozone.com/autozone/acc...er=555441_0_0_
DG Rider is offline
post #8 of 11 Old 07-27-2014, 01:05 AM
Quoted: 10 Post(s)
How did it get bent? Hit something with tire?
Bayouownbeer is offline
post #9 of 11 Old 07-27-2014, 08:17 AM
Da-veed's Avatar
Good write up!! Keep them coming!
Tyler
2011 silver GMC 2500 crew-cab duramax 4x4 leveled on 35's
1993 Toyota single-cab pickup 4x4 lifted and big bumpers
No pioneer........yet.
Da-veed is offline
post #10 of 11 Old 07-27-2014, 08:40 AM Thread Starter
I'm not sure. My sister and daughter went out riding. She said she was turning and the front tire grabbed and spun her the opposite direction into a tree. She must have hit hard to bend it that much, especially given how short it is.
Volnut is offline
