How much oil left if not registering on dipstick? - Honda Pioneer Forum
post #1 of 7 Old 05-29-2019, 10:13 PM Thread Starter
Anyone know the max amount of oil left without registering on dipstick?
dougd5589 is offline
post #2 of 7 Old 05-29-2019, 10:19 PM
Iím guessing youíre down at least 1.5 quarts.
Sent from my iPhone using Tapatalk
drdarrin is online now
post #3 of 7 Old 05-30-2019, 08:08 AM Thread Starter
Thanks drdarrin. That's all? Interested in any other opinions. Dealer snafu servicing - did not set some bolt to proper torque when checking/adjusting valve clearance - oil leaked on engine causing lots of smoke, scared crap out of me. One check showed oil level at lowest normal range. I tried to limp back to civilization, but amount of smoke/smell caused me to stop again. Oil check here did not register. I drove no further and had to hike. Freaked out I may have rune even a little bit with no oil-Yikes. Brought it to dealer and they said there was 2 quarts remaining despite dipstick being dry. Of course they want to CYA-so looking to confirm?
post #4 of 7 Old 05-31-2019, 02:16 PM
Quoted: 210 Post(s)
I'm surprised the 700 would keep moving with just 2 quarts in it. The transmission will stop working before it gets low enough on oil to do harm to the motor.
post #5 of 7 Old 05-31-2019, 02:45 PM
My experience with the 700 is very limited. Iíve owned my 2016 for little more than a year and Iíve added less than 300 miles. It only gets used in the Arizona desert during the winter. Iíve changed the oil once, just before storing for the summer months. So, like most, Iím still learning.
Since your oil level got so low, Iíd keep a real close eye on metal shavings in the oil. Hopefully no damage was done but you never know.
post #6 of 7 Old 06-05-2019, 11:09 PM
I recently purchased a 2016 700 that’s had 9000 miles on it. I put about 60 miles on it and it and one morning went for a ride and that night wouldn’t move anymore. Checked the oil and nothing on the dip stick. One whole quart put the level right at the very bottom of the dip stick, I put almost two whole quarts in it before it was to the full line. Called the place I bought it from and they ended up rebuilding the engine for me thank goodness! Running great ever since!
Rubirider11 is offline
post #7 of 7 Old 06-27-2019, 08:39 PM
I know the problem!!! I just posted this as you did!!! pretty weird.....
the dipstick cannot be screwed in to check oil!!!!! its in the service manual!!!!
You could be in the LIMP MODE or have a damaged engine or a lobe on your cam....
jumper the diagnostic wires, brw/red to green...don't buy the tool, just use a single wire....IF no codes but the engine light is on....well, that's where I am at....it seems NOT to want to go into 3rd gear, the limp mode....to prevent further damage...
I'm adding oil now to see...but I cannot clear the code out...soooo, I may be in trouble either way..I'm in the bush....
do NOT screw in the dipstick...
this is the STUPIDEST thing I've ever head of...every other machine I've owned was opposite...screw IN the dipstick, screw out and check...right in the kawasaki book!....
stu-pid....but, I didi not read the manual!
jssbastiat is offline
