instrument meter replacement? - Honda Pioneer Forum
post #1 of 2 Old 10-11-2020, 10:16 AM Thread Starter
Hi:
I have a 2017 700 pioneer. it has a voltage leak that drains the battery about every 4-5 days. When I unplug the wire harness to the dash display, the voltage leak stops. I am now thinking the leak has to be in the dash display, instrument meter, or the meter harness.
My question is:: do I have to remove the dash to remove the instrument digital display? and what is the normal amp draw from the battery when everything is normal? It now draws 25m amps.
Thank You
Oldnewrider is offline
post #2 of 2 Old 10-12-2020, 07:12 PM Thread Starter
Just thought I would post what I found. The instrument panel can be removed without removing the entire dash. Also .25m amps is well below the maximum draw limits.
So I am back to where I started. What could cause the engine to turn over slower then normal after a couple of days if there is no electrical drain.
When the machine turns over slower then normal it usually will not start.The battery is a new Yuasa in fact it is the second one I have used in the machine. I brought the starter in and had that tested. Tech said it was fine.
Anyone with any ideas?? because outside of Gremlins I am stumped.
