Ride all winter long!
Link:
https://www.superatv.com/honda-pioneer-1000-cab-heater
You need SuperATV's Cab Heater because your Honda Pioneer 1000 is made to ride in the winter even if you're not. It draws engine heat directly from the coolant lines to heat your cab just like a traditional car heater. Install is easy-we include hoses, drill-bits, and Pioneer-specific mounting plates to make it as easy as possible to get your heater up and running. With the unit mounted between the seats under the dash, you get balanced cab heating right where you want it. With adjustable temperature, and adjustable fan speeds, winter might just become your favorite time to ride.
Defrost Your Windshield Along with the two vents in the unit itself, we include two defrost vents and hoses to keep your windshield snow, ice, and fog free while you're driving! We route the defrost vents through your dash, so they look like they came included from the factory.
Keeps Your Cab Comfortable
Our Cab Heater is designed to make your cab comfortable while you're riding. The high-grade radiator hoses are rated from -40°F to 285°F. That means that no matter how hot your engine gets or how cold it is outside our heater and its components can handle it. Our heater doesn't just make you more comfortable-it makes your winter better.
Need More Protection?
Get the most out of your cab heater by completely sealing your UTV's cab with our full doors, roof, and front and rear windshields. Check out SuperATV's full line of Honda Pioneer Windshields.
FITMENT
FEATURES
Link:
FITMENT
- Honda Pioneer 1000 : 2016+
- Honda Pioneer 1000-5 : 2016+
FEATURES
- Adjustable temperature and fan speeds
- 360° adjustable vents
- High-grade radiator hoses-rated -40°F to 285°F
- Includes defrost hoses and vents
- Draws 3.4 amps at 13.7 volts at full fan speed
- Built-in shutoff valve
- Easy install-includes all installation hardware and instructions
- Heater control box measures 10" x 4.5" x 11.75"
