Specifications
ENGINE
Engine Type - 675cc liquid-cooled OHV single-cylinder four-stroke
Bore And Stroke - 102.0mm x 82.6mm
Compression Ratio - 9.2:1
Induction - Fuel Injection (PGM-FI), 40mm throttle body
Ignition - Full-transistorized with electronic advance
DRIVE TRAIN
Clutch - Automatic
Transmission - Automotive-style with hydraulic torque converter, three forward gears and Reverse. Three drive modes include 2WD, 4WD and 4WD with differential lock
Driveline - Direct front and rear driveshafts
CHASSIS / SUSPENSION / BRAKES
Front Suspension - Independent double-wishbone; 7.9 inches travel
Rear Suspension - Independent double-wishbone; 9.1 inches travel
Front Brake - 200mm hydraulic disc
Rear Brake - 170mm hydraulic disc
Front Tires - 25 x 8-12
Rear Tires - 25 x 10-12
DIMENSIONS
Length - 114.8 inches
Width - 60.0 inches
Height - 77.6 inches
Wheelbase - 76.8 inches
Bed Capacity -1000 pounds
Towing Capacity - 1500 pounds
Ground Clearance - 10.3 inches
Turning Radius - 14.8 feet
Curb Weight - 1261 pounds - Includes all standard equipment, required fluids and full tank of fuel?ready to ride.
Fuel Capacity - 8.2 gallons, including 1.2-gallon reserve
OTHER
Note - Recommended for Drivers 16 years of age and older.
Available Colors - Red, Olive, Honda Phantom Camo™
Model Id - SXS700M2
FACTORY WARRANTY INFORMATION
Duration - One Year
Description - Transferable limited warranty; extended coverage available with a Honda Protection Plan
ENGINE
DRIVE TRAIN
Clutch - Automatic
DIMENSIONS
Width - 60.0 inches
OTHER
Model Id - SXS700M2
Duration - One Year
