1 - 6 of 6 Posts
I sunk my Honda pioneer 700 got water in air box I never started it brought it home flushed it out cleaned everything put fresh oil started it up runs fine but now I drive it 10 ft or so and it won’t go anymore my transmission is slipping feels like I took apart the main valve body cleaned it twice checked the three sensors packed them with dielectric grease and it still doing it can anyone point me in a direction to why it’s still doing this?
Yes I did I cleaned the main valve body 4 times flushed oil out probably 10 times oil looks good in motor now rear dif and front dif look good I changed those I took apart throttle body cleaned those put dielectric grease on all connections and still goes about 10ft and don’t go no more I can rev it up as much as I was n drive or reverse and it won’t move let it sit for awhile it will go about 10ft and do the same
This just happened to me as well, swamped my 2014 P700. I flushed approx 10 times as well, reassembled, went for test ride, and feels like tranny is slipping.
Does the tranny not separate from the motor, oil?
1 - 6 of 6 Posts
