Hi I have a 2019 pioneer 1000 that recently started cutting off after 15-20 minutes. I have checked the fuel pressure and changed the fuel pump with no results. Can anyone point me in the right direction?
Mine did same thing do you get a check engine light that flashes one long and three short flashes? if so it is a broken fuel injector plug wire.on the back cylinder, cost about $20 and about an hour of your time to fix. Mine would start right back up and then shortly do it again........
2017 Pioneer 1000-3 LE
I does sound like a broken in injector wire. Amazon has the pigtails (plug ends) for sale for $25.00. The wire can break from vibration under the insulation and you would not know it.
