New Here! I purchased my 700-4D back in May 2020 and am wanting to add some aftermarket accessories. I understand the basics...a need for a relay for keyed power and the use of the fuse block for distribution to the accessory and the rocker switch(es). I plan to run power cables directly from the battery to the relay. I will use the Honda sub-harness/cigarette lighter to provide the keyed power switch. My question is do I add an in-line fuse (say 30 amp) between the battery and the relay? I don' have a winch (yet) and will direct wire that to the battery if I decide on that at a later date.
Any advise and/or wire diagrams is appreciated!
