1 - 20 of 49 Posts
I thought the roof added 4" ?
its like 3-4 not quite sure on the 2 seater. but mine is about 3 inches higher than the rool bar. but if your going on factory height vs 27 inch tire height id have to air my tires up to spec before i could give you a good measurement 8 and 10 psi i lose a lil under a half inch in hieght
Mud lite XTR
Thanks, im still trying to figure out if I can get it in my garage with 27" itp mudlite xtr's and a 2" lift kit
Thanks
Did you get the tires? If so, what'd it measure? Curious to see pics too.
Thanks
Discussion Starter · #16 ·
Im still waiting on my pioneer also said it could be sometime in April before i receive mine... but done got wheels and tires and and graphics kit in the garage? just hope it fits in the garage after the tire and wheel install
I'm running 27" mudlites with 10 psi rear and 8 psi with honda roof and no lift. Will fit in my garage at lake its a 7'x7' door with about 2 inches to spare, I will however not fit in my garage at home with roof on and that door is a 8'x6.5' door, hope this helps
1 - 20 of 49 Posts
