Rellison110 did an outstanding job of tracking down the components to make (non OEM) plug n play in your accessory fuse box and switch panel.
I am reposting his info here, and I would like for it to be considered for "sticky" worthiness.
Thanks again Rellison110 for your efforts.
Using Hondas Accessory Fuse Box for non Honda Accessories
by rellison110 » Sat Dec 28, 2013 1:00 pm
For those of you that either have or plan to install Hondas accessory switch panel and fuse box, there is an issue that has frustrated me to no end. The switches and plug in connectors are vendor are and proprietary to Honda. Fortunately for any Pioneer owners wanting to install this, I have located and now installed non Honda items using their accessory fuse box and switch panel.
The connectors and associated pins that go inside the connector are available from Mouser Electronics.com and the part numbers are as follows:
Two pin is 538-50-84-1020
Three pin is 538-50-84-1030
Four pin is 538-50-84-1040
The pins is 538-02-08-1002
I have only used the two pin so far, as that was all I need so far. I soldered my connectors.
I purchased switches from OTRATTW.com and they are Carling Tecnologies V series. I chose the Contura two which have two illumination functions. They illuminate with a bar at the bottom of the switch when the head lights are on, and then the designated symbol on the switch lights up when the accessory is in use.
You will need to modify the Honda connectors that plug into the switch panel per Carlings switch wiring diagram. I wired directly into the head light switch wire for the lower illumination function. It is a black and white wire that is under the hood, by the wheel well on the drivers side, and is a two pin connector that if you pull it apart, will disconnect power to the head lights, that will tell you that you have the right wire.
