How much do you enjoy that giant orange and white sign in the middle of your dash? Me personally, I could think of better places for it. Not only for the fact that it's ugly, but it eats up so much useful real estate on the dash!
WARNING: this process is not for everyone. I, in no way am telling you to remove warning stickers from your Pioneer.
Ok, now that the legal crap is out of the way, I'll get to what I did.
I looked at that label one more time...... Sorry buddy, you need to go.
I then inspected the back of the dash behind the warning label. You can do this by removing your hood. Area was clear of obstructions, so I continued on.
I found a drill bit to pop the rivets with. The drill bit only needs to be as big as the center of the rivet. Once you have drilled through the head of the rivet. The back side will just fall out.
With all the rivets removed. Pry up an edge of the sign. Once I got my fingers under it, it peeled right off.
There is some factory adhesive left, so I used a little cleaner and elbow grease to remove it.
Then I decided where I wanted to put my first Aux switch. After making a few reference marks, I used a Dremel with drywall cutting bit to make the hole. Take your time on his step. If you screw up, you can't go back.
These Daystar switches are from Amazon. When you have the hole just right, they are self locking in place. I kept my hole on the small size and used a series of "dry fits" to get it just right.
Since I was doing my front and rear LED's. I only did two switches. I plan to add a dome light with switch and use the rest of the area for my winch remote and switch, and a couple USB charger outlets.
I ran all wiring under the body and zip tied to the frame. I hooked a fusible link into the positive battery terminal, so the lights are operated independent of the key.
I did have the assistance of a master electrician in training for a lot of the install.
The sign has found a new home proudly displayed on the rear of my roof. Safety first!!
