1 - 20 of 67 Posts
Has anybody else experienced this. It seems like it only does it after I remove a large payload from the bed. (like firewood) The brake pedal will go to the floor but is fine after you push it again. Any Ideas?
Yes, I have experienced this as well. Mine doesn't go all the way to the floor, but the pedal does travel further to start braking. Almost feel like air in the system, but it's intermittent.
Maybe the park brake uses the same system as the hydralic brakes, this could cause the piston to relax and require a pump to bring the brakes back?
Like what Ryan says. I hadn't really put much thought into it until probably about three days ago. I was pulling into the garage and went to apply the brakes as I normally do, but the pedal travel greatly increased and I ended up bumping my sons ATV bumper. I asked my wife about it as she runs loads for me a lot, and she hadn't recalled any such incident. I would say it has happened to me, maybe 4 times in all my miles. I don't ever do real heavy braking and use the engine brake in correlation. So nothing was over heated. And I hauled about a 1/2 load in it last night and had no issue. I checked the fluid and it looks fine. I also had all the tires off last week and upon visual inspection, nothing was wrong with the discs in the front.
I know someone here mentioned the parking brake. I do use it, but again, can't verify it's use before each incident.
I am keeping a lot closer eye on it now to see if I can narrow down an issue of cause.
I had a few thoughts but none of them are really possible. The rear brake system is mounted pretty stationary to the final drive. My first thought was motor torque flexing the driveline just enough to put pressure on the disk/brake pads allowing them to compress a little. Not possible unless the pinion joint nut is missing or loose. Brake lines are all pretty stationary also and free of obstructions (unless a few machines was routed wrong from the factory).
I've looked over the machines I have here and nothing obvious has presented itself. If I hear anything from Honda or think of something to check I will post it up.
Brake pedal goes to the floor.
My Pioneer has done this also. When this happens on our aircraft it always involves bleeding the brakes due to air in the system. Requires two people to get the air out. One to open and close the line while another pushes the pedal. If so many owners are having this problem the factory is putting the brake fluid in improperly.
I have bled mine and it made no difference.
Discussion Starter · #19 ·
I think I may have discovered my problem. I purchased the aftermarket front a arm guards off of eBay. They don't fit reel well on they tire side, so every time you turn hard left or hard right the brake caliper was hitting the guard. I had the front end jacked up and would turn hard left and hard right and then press the brakes and every time the pedal would go almost to the floor. I adjusted them by bending the them and make sure they were not hitting. I then turned the wheel hard left and hard right and couldn't get the pedal to drop. I even drove it a couple of miles and couldn't get it to do it. Hopefully that is all it was.
1 - 20 of 67 Posts
