Hi all, I’ve been searching for this and no good threads I can find.
I have a 2015 700-4 that I got in summer 2022 and it leaked coolant in the oil - drained all and used a rad sealer and was good until this past week while snowploughing. Looking for input on the troubleshooting…
No evidence of combustion gas in coolant or white smoke. Level in rad is too low to see and overflow bottle is empty. Engine oil level is up and milky. Purchased the 2014 service manual in summer. No coolant leaks visible outside or on shop floor.
Since the water pump has a weep hole, can’t be that.
The oil pressure is higher than coolant pressure so can’t be oil cooler tubes but the manual shows an o ring seal on the back of the cooler. Could be this seal.
Likely culprit is the head gasket around a coolant gallery going to an oil drain gallery to sump.
Any other ideas?
I’m gonna throw the compression tester and see what I get compared to the manual.
Picking up a rad tester to pressure up the system, but if either the head gasket or oil cooler leak and piddle out the sump drain hole it still doesn’t tell me where to start.
Any other ideas?
