1 - 20 of 29 Posts
If your not planning on a heater, under the hood is a decent option. There still might be room for both if you are, depending on the sizes you go with.
There is enough room close to the battery area depending on the size of battery your adding. You can build a box between the electrical and motor (I would add a heat shield also just because), If a 2 seat model there is a lot of room in front of the rear wheel area to add a box for it. Once you get the machine and get to look around I don't think you will have any problems finding a suitable placement for it. What you have for cable length and size of the battery might be the deciding factors.
I ran the wires across the front of the motor and zip tied them to the frame (which would be behind your knees when sitting-under the seat of course). I used a battery mount to tie it down to the aluminum metal plate. Ill see if I can get a picture.
1 - 20 of 29 Posts
