I had a good 50 mile ride on the pioneer today and had the following observations. It has plenty of power and will run up to the limiter with no problem. It climbed very steep hills that I did not think it would without a low range tranny. Many magazines that tested the prototypes thought the suspension was soft. Honda must have listened because I found it to be a little stiff but that is a good thing since the springs will no doubt relax over time. On the loop running mostly around 35 mph it turned in 21 mpg on a new engine. Things I would like to improve on are, 1. Make throttle pedal a little bigger and longer. 2. Tilt steering would have been nice but the steering was very easy except in 4X4 with dif lock on.3 Rear view mirror. 4. I need to adjust the rear bed as it squeeked over all the bumps. Over all I think it felt better than a stock 50 inch rzr but it is not as fast on top speed or as quick.
