1 - 11 of 11 Posts
Hi friends,
Is anyone out there with the mystery resolve about the graphic kit for the Honda pioneer? We should buy it or not? Any other suggestion? The kit is quite expensive and I don't want to waste my money if they are low quality. They stick well in the rough surface? Please share some pictures...
Cheers!
No they r not factory, what I did is got thin aluminum sheet metal, cut it on a band saw to fit each piece, then went and got red vinyl that I knew would stick to the aluminum, then I took very corse sand paper n got the back of the aluminum and the plastic on the Doors to ruff it up then used 3 m super weatherstrip adhesive and glued on, I also painted up some small screws, with the same red I did my bed extender so if I have any trouble I can put them in each corner, I only wish I would of thought of the screws first bc the pieces are curved and it was a real pain clamping them on to dry, it was a real pain in the ass but I am glad I did it cause I'm the only one that's got them so far, but the only place I can show them off is here bc a non pioneer owner wouldn't even know
I didn't really plan it out, I pre ordered the web part from a cnc in Tennessee, I just took a tape and cut some steel and let it com together, I did get the web a little big so I could cut it down as needed to fit after it bas built then weld in, Angela it's bolted through tailgate and through the d rings in corner of bed
No these are not for sale and will not be.
If you look on the pioneer where the stickers are suppose to go the plastic is not smooth. So they can not and will not ever work.
So if they change the design in the production of the beds they could redesign them so the stickers will stick. But for us newb's the stickers will never work right on the plastic.
Gorilla glue Utard. Then we can stick them like its meant to be.
Reactions: Utard
1 - 11 of 11 Posts
