Research UTV diesel air heater. Best that I have read about. Sort of a DIY thing.
You put in the bed in the winter time and take it out when you no longer need it.
Most that are installed, do not work well enough to keep you warm with all the air gaps we have.
Have heard of some owners like their Inferno Cab Heaters.
A word of WARNING.
DO NOT mount a heater under the driver seat.
DO NOT let any Dealer mount a heater under the driver seat.
"But, but, the dealer says they put them there all the time."
Dealers are there to make money, and they do..........when the ECM/ECU goes through to high of heat cycles. hot then cold, hot then cold. YEP, it works fine for awhile, then the heat makes it weak.
Have read to many stories, "My machine shuts down after it get hot."
and the dealer will troubleshoot and troubleshoot.
End result, bad ECM/ECU.
edit to add
Also have read many who just use a buddy heater, or a golf cart heater and are happy with that.
