I know this method isn't for everyone, but if you are looking for a good durable windshield that doesn't cost an arm and a leg, this might be an option.
1. You will need a Lexan of your choice. I went with a version that has UV protection on both sides.
2. Self adhesive weather stripping. I went with a 1" foam.
3. Zip ties.
Tools: something to cut the Lexan (unless you have it precut). I used a Dremel sawmax. Plus a drill to make the mounting holes.
Estimated project time: under 30 minutes.
I was able to pick up a 36"x48" sheet for $75 from a hardware store.
I measured the space available. 48" was perfect for the width and 30" for height. I snapped a line on the Lexan and used my sawmax with a multi purpose blade. (If you don't work with This material a lot, I suggest setting it on cardboard to cut. That way any extra blade depth isn't hitting your work table and it allows you to cut on a flat surface so the sheet doesn't bend.
I took the cut to size sheet and peeled back the protective film enough that I could apply the weather stripping to the edges on the back sides. I then drilled my mounting holes.
The next step is mounting to the machine. A second pair of hands here would make it a simpler process, it can be done with one person, but you can't be unwilling to have some zip ties in your mouth
After it's secure, peel off the film and your ready for the trails.
A photo looking through the new windshield.
Shot to compare looking through the Lexan compared to looking through nothing.
My total cost on this project was $75. As I had everything on hand but the sheet. The windshield is quick to detach and it only takes 6 zip ties to put it back on. So if you remove your roof and windshield to haul the Pioneer, it's a quick off and on process.
3. Zip ties.
