1 - 14 of 14 Posts
Hi I'm new to the sxs scene. I just purchased a 700-4 with the warn 72" plow and mounts, all through Honda. I've called Warn and can't get a straight answer as to if a Power pivot will fit the Honda mounts? I would assume so being as the Honda plow sports Warn badging. Any help would be appreciated.
Welcome to the forum. I would make that assumption as well. Toodeep a moderator here has a family honda dealership. I'd bet he knows or could find out right quick.
If restocking isn't bad, probably worth a try.
That's funny, I called Warn and asked the difference in part numbers I'd seen listed on different sites. And he tried to tell me there was only one Power Pivot. Not a mention of the Pro Pivot. Apparently he wasn't very knowledgable. Thanks for the info. I never caught the name difference.
Well, I ordered the Pro pivot today. Hopefully it mounts up. Now I just have to wait to see what shows up first, the Pioneer or the PP.
I read that it only worked on ATV's as well, but the guy at Warn claimed it worked with 72" Provantage plows, just didn't know if the Honda push tube was the same. I should know later this week. Im getting pretty antsy waiting.
Discussion Starter · #11 ·
I sent it back yesterday. It could've fit with a little fabrication. But it isn't bolt on for the Oem push tube. After plowing the trails at my land, I don't think it would have been heavy duty enough for me anyway.
FYI everything bolted on nicely, but the main
Carrige bolt heads, that mount the push tube to the blade, would have to be ground down to fit the pivot motor. And the oem mount lacks a welded on bracket/anchor point needed.
Thanks for updating this. That's good info.
1 - 14 of 14 Posts
