Honda Pioneer Technical Data (Specifications)
Going to go over some specs that I can find online
Model: SXS700M2
Engine Type: 675cc liquid-cooled OHV single-cylinder four-stroke
Bore and Stroke: 102.0mm x 82.6mm
Compression Ratio: 9.2:1
Induction: Fuel Injection (PGM-FI), 40mm throttle body
Ignition: Full-transistorized with electronic advance
Clutch: Automatic
Transmission: Automotive-style with hydraulic torque converter, three forward gears and Reverse. Three drive modes include 2WD, 4WD and 4WD with differential lock
Driveline: Direct front and rear driveshafts
Suspension
Front: Independent double-wishbone; 7.9 inches travel
Rear: Independent double-wishbone; 9.1 inches travel
Brakes
Front: 200mm hydraulic disc
Rear: 170mm hydraulic disc
Tires
Front: 25 x 8-12
Rear: 25 x 10-12
Length: 114.8 inches
Width: 60.0 inches
Height: 77.6 inches
Ground Clearance: 10.3 inches
Wheelbase: 76.8 inches
Turning Radius: 14.8 feet
Towing Capacity: 1500 pounds Payload Capacity: 1000 pounds Fuel Capacity: 8.2 gallons, including 1.2-gallon reserve
Colors: Red, Olive, Honda Phantom Camo Curb Weight*: 1261 pounds
Model: SXS700M2
Clutch: Automatic
Suspension
Brakes
Tires
Front: 25 x 8-12
Rear: 25 x 10-12
Width: 60.0 inches
Height: 77.6 inches
