What is the best way of going about tapping into ignition power source for electronics to only run after the key is turned on?
the main cables go from the battery but if you are looking for 12volt keyed for the switch (trigger) then yes find one of the wires from the ignition that is only hot when the key is onThere is no place to tap ignition power for a winch. You have to go directly from the battery. Light or lite power draw can be done from cig lighter harness but not a winch.
he can run the winch from the battery with a solenoid and make it keyed for the solenoid to be activethe main cables go from the battery but if you are looking for 12volt keyed for the switch (trigger) then yes find one of the wires from the ignition that is only hot when the key is on
