New shoes for new machine and will link some pix.
Rims are 12" and 7" wide with 5"+ 2" offset.
Tires are AMS Slingshot 26" by 11" on all four corners
Do not touch at full lock, full suspension droop or sitting static and I don't think at full compression either.
Ground to frame clearance is 11" after install, with rear suspension at lowest setting.
Stock rear tire/rim weights (crappy bathroom scale 30lbs) and new 37lbs.
Only driven 100 metres and back on pavement and tire diameter seems just right for gearing, will know better after a rip in the dirt tomorrow.
Gonna be a mud thrower on the front I fear and am planning on fender extensions using UMHW sheeting cut and fastened with push pins, more on that after I get sheeting....
Link to pix
P500 pix
Link to pix
P500 pix
