1 - 20 of 35 Posts
Or would that be the savvy mans version??? lol
Ok, drilled out the rivets and yanked the warning plate a la Moose.
Then, cut me out a plate of aluminum.
Squared it off pretty good, and brushed it nice an clean.
Left a 1" border of the dash and cut out a nice lil hole.
Mounted up and in place.
Now I just gotta order me up some switches. Im thinking interior lights, forward LEDs, rear LEDs, and I may try to add in a handlebar rocker for the winch and mount it in there.
I was gonna paint it black to match the dash, but, I kinda like the brushed aluminum look.
All in all, for the cost (free) im pretty happy bout it.
Looks good
Did you isolate it at all. (Rubber or gasket behind it). I guess my question is, is it going to rattle at all?
I like the look! I wouldn't say its the poor mans version. My stock dash is the poor mans version. :)
Yours is the heavy duty "brushed" aux panel.
Ive been passing by it all day, taking a look at it from time to time.
Yes, I think I will put a coat of flat black on it.
Amazon just hit me up for the cost of 4 LED floods, a roll of LED strip lights, three switches, and a Warn Handlebar rocker.
Fun fun.
What's holding those screws in? Oh....I like it a lot! I'm just wondering what you do now to add switches? Is it going to be easy to take the plate on and off?
I'm a wiring novice......maybe even less than that!
DB
I will take my time with a dremel and machine out, well, gnaw out, the approriate size mounting holes for the rockers and the Warn switch. Once everything fits to my liking, I will paint the plate and reinstall.
Looks good, thanks for sharing.
foggy call me cheap but that's kinda expensive for a couple toggles and a plate
I mean I know they have lots of options but dang
Discussion Starter · #16 ·
Looks great. I was thinking of a checkerplate painted black piece.
That would look pretty slick too.
I just happened to have a bunch of thin plate lying around.
I also have some 1/2 aluminum plate. If I had a CNC mill I would have used that and machined out the Honda logo on the bottom of it and painted it black with the logo in grey lettering. That would be sweet.
Anyone wanna donate to the buy a poor ******* a CNC mill fund???? lol
Yep, I agree it's a bit more than you can find others for. However it is the panel, six marine quality switches, each fused (circuit-breakers) separately, and its all pre-wired in a harness. So….it's one good alternative.
I have seen other switches too. I committed to the Honda wiring and switches…..so I used up my options. Just adding some alternatives to others faced with the switch decision.
true. iv been looking for a volt meter for cheap to wire in to the key or radio switch. im thinking ill wire it to the radio switch since ill be running an aux battery later. I just got my switches in like moose and some leds so im mounting them tomorrow but I need more switches I think im going to do like moose and put leds up front but thinking of 45 degrees out cause of my area. also thinking about the waterproof usb's I can recess some but they are from china so ill order them before I get back next hitch. all in all I like moose's setup and blakes setup but im not particular to shiny stuff and if I wanted to skin it I can skin plastic no problem
hey blake what did you cut the aluminum out with. if you have use of a plasma torch you can draw out your design and cut inward at an angle and cut the design out and then if you do it at the right angle you can recess the cut out beneath with a couple tac welds.
$50 bucks for just the plastic? Jeez
1 - 20 of 35 Posts
