Think it's possible you have any air in there Foggy? Did you try elevating the front and removing the radiator cap to make sure she has a good burp?Installed my Honda heater today. Not much heat output. I blocked off the entire radiator…..only got two bars for heat despite a super long ride and wam up.
I can feel a small amount of heat coming from the ducts….but you don't want to leave your gloves off too long at 0 degrees f.Never really warmed the cab…..and you could see your breath after an hours ride. I doubt if I raised the cab temp 2 degrees.
Disappointed? Yep.![]()
Didn't try any "burp". Maybe tomorrow. Not much heat output the way it is. Drove it for an hour. Maybe I got air….dunno.Think it's possible you have any air in there Foggy? Did you try elevating the front and removing the radiator cap to make sure she has a good burp?
You are the 4th confirmed heater ain't worth it that I have heard......
What did you do to get the air out?Installed my Honda heater today. Not much heat output. I blocked off the entire radiator…..only got two bars for heat despite a super long ride and wam up.
Sounds like you still have air.Didn't try any "burp". Maybe tomorrow. Not much heat output the way it is. Drove it for an hour. Maybe I got air….dunno.
Cant get the heater past two bars despite blocking the entire radiator. Got cold…..had to come in.
Maybe some type of block heater?I've given up waiting for the appropriate bar reading to take off. Below zero, I give it 10 minutes, I just can't wait all day. It will still be reading lo 1/4 mile down the trail.
