How did it go? Everything smooth as silk?
Depends. If a sxs and an ATV had the same clearance and tires. I'd say the sxs would be better. More weight won't get hung up as easy. That would depends a lot on terrain and snow type tooAre these things (sxs's) as good in the snow (on tires) as ATV's?
Have you ever been stuck with tracks?In my experience sxs are better unless you get stuck. Then the extra five hundred lbs is a if deal. If the snow is barely hard enough to ride on top of then the Atv is better for staying on top. But that can be dangerous if you are traveling fast and break through you can cartwheel pretty easy with the higher enter of gravity on an atv
I used to use a rincon with tracks at an old job.Have you ever been stuck with tracks?
