So I am going to start adding accessories to my pioneer 700-2
My plan is to wire in a 30amp relay that will then send power through to my switch panel.
--I plan on adding a 20" lightbar
--Stereo with 4 speakers (purchased a box from FrogheadATV)
--Rear cargo LED lights(2 small ones)
My main question: What is the best wire to tap into for the IGN line on the relay? Should I use a relay? or just wire in a master power switch so that I could use it without the key on.
also, where would be the best place to run the wires from the battery to the relay and switch panel underneath the front hood?
I was also looking for some recommendations for where I should mount the relay and switch panel.
I'm adding a winch as well, but going to be using a separate relay and switch for that?
I'm open to any and all advice/suggestions.
