Not a bad idea to use run flats for sxs But I would imagine the ride would be rougher on solid pavement.
never used that stuff, how long does it take to do it's job when you get a puncture?I run tire slime in my ATV, tractor, and truck tires. The stuff works unless you have a huge hole, or a slice to the sidewall.
If your tire is moving when the puncture occurs, the centrifugal force pushes the slime into the hole along with the tires air pressure making it work almost instantly.never used that stuff, how long does it take to do it's job when you get a puncture?
The way I constantly battle chipmunks red squirrels and mice around here. I wouldn't be cleaning mud out of the holes, it would be mice nests, acorns, and small fur bearing mammals.Those airless tires look like they will be on everything. Saw one of those shows where they put them on a car. They were bookin it too! With reguards to them filling with mud, im sure they could make a set with a thin layer on the outside to keep the holes from filling. If the price is right, id buy em.
