1 - 8 of 8 Posts
i am new to this site and new pioneer owner i was wondering if i snorkle my bike what lines do i also need to run up beside air intake.
does it have transmissions lines and what about diff vent lines ect.
also what size pipe would be good so i dont mess up stock air flow
Hi Jamie welcome to the forum.
I have not checked the rear yet but I did notice the front differential is vented high up under the hood into the frame. You can see it the picture below at the far right about 3/4 way down.
You should have your front/rear final drives and cooling fan. I can't think of anything else at the moment that is vented on them. I would think a 2in snorkel would do the trick on these. I know the Rincon will run good with that size which is the same motor. Of course every bend in the routing makes a difference plus location.
A 2 inch is what my dad put on his big red and he hasnt shown any loss of power. The front rear and fan need a to be ran up just depends on how deep your taking it. You can just make a large downward point and you wouldnt have to worry about the front and rear. Not sure on the fan im not plan on going that deep im just going to run my rear and front up about 6 inches higher than they are the straight line them back down a foot. Did great at keeping the water out of the diffs on my old bikes.
Well the snorkel is good enough depending on how deep of water if you need a snorkel also then you need to make sure everything is good lol
1 - 8 of 8 Posts
