1 - 2 of 2 Posts
Hi
I have 2016 honda pioneer 1000-5 deluxe. I was thinking about getting 4 - 30x10x14 tires . Do I need to change front rims where they are narrower than the back. Im thinking putting these tires on the narrower front rims would make a height difference therefore in 4wd they would be a different ratio and may cause problems
TIA
Vendor
You'll probably need to upgrade quite a few things before running 30"s. You can probably pull it off without any rubbing with...
- Forward offset A-arms: https://www.superatv.com/honda-pioneer-1000-high-clearance-forward-1-5-offset-a-arms1
- 3" lift: https://www.superatv.com/amfile/file/download/file/2784/product/8171/
- Rhino 2.0 axles all around: https://www.superatv.com/honda-pioneer-1000-axles-rhino-2-0-brand
- And wheel spacers all around: Currently out of stock
You can pull off some 28"s with just the forward offset A-arms and wheel spacers.
1 - 2 of 2 Posts
