In your
other thread, I posted a link to get a digital copy of your Owners Manual.
Some very important pages to read are:
- page 26 and page 31 information about your seat belt speed limiter
Have read about many new owners," Why won't my Honda won't go over 15mph?"
And......I was one of them. HAHAHAHA!!!!
- page 48, 50, 114, 116, 120
Read and heed that notice (complete stop and engine at Idle) before moving shift lever.
It is on so many pages, YES!, it can and will damage your transmission.
- page 50 changing drive modes
If you are in 2WD, 4WD, or 4WD Diff Lock, on hard dry surface, pavement is even worse, you will feel it/hear it.
The differential gears are slightly different sizes. The tires, for sure, are different sizes, even when new. And now you tie them together, all to the same driveline, and force them to turn at the same speed. On dry surface, the gears are binding, fighting against each other, there has to be slippage somewhere, and you feel it as vibration. Hopefully you only feel it as slipping of the tires.
- page 114, 118, 128
The Notice read it all, now read it again, ok, now read it again.
Simple explanation: IF your wheels are not turning, your foot better be on the brake.
Fail to heed that warning, and you will be replacing your clutches.
Now, to answer a few of your questions.
When to drive in Turf vs 2WD vs 4WD vs ? page 120
(complete stop and engine at Idle) before moving shift mode lever
Riding my trails, other trails, our Iowa gravel roads, in town, highways, you name it, I am almost always in turf mode.
This hill, haha, on a trail that the wife and I found while cruising Iowa back roads, I was in turf mode.
I plow snow in Low and 4WD mode.
Your "normal driving" as you described, you will probably be in High, turf mode.
When to be in low vs high? page 116
High most everywhere.
Slower then 10-15 mph I will probably be in low.
My trails that I know, high.
That
Cedar River trail that we found, most of it, I was in low.
