1 - 20 of 51 Posts
These just came in this afternoon. I will update how the install goes.
Around $175 for fronts and backs shipping included. They were in 2 days after I placed my order.
I bought them through eBay.
2014 Honda Pioneer 700 700 4 UTV Aluminum Front A Arm Guards | eBay
Mr. Smith,
They are aluminum guards that protect your A-arms and your axles, boots, etc.
They still have a protective film on them, as I will leave that on until just before install. I will be sure to update with installed photos to clear it up for you.
Thanks for the info Moose,
Went to your link and will be ordering two sets this week. Good find!
And they look good in the pictures.
Here is the install update. The guards are 1/8" aluminum. feels very study. Fit and finish was very good. On only a few corners of the cuts had the water jet undermined the protective wrap. There weren't any directions included with the parts, but it was a pretty straight forward process.
You are going to need a drill, 1/4" drill bit for metal, and a 7/16 wrench. I used a ratcheting wrench personally and it worked fine.
First step I did was removing the protective film on the guards. It can be a little hard to get the edge to start peeling, but after its started, even my 5 year old had no issues peeling it.
I installed the backs first. Only one hole has to be drilled. I raised the Pioneer high enough up on blocks under the wheels that I could get my drill under it to drill upward. I used the guard as a template. holding where I wanted it with one hand while drilling with the other. I drilled just long enough to score the surface then I set the guard aside and finished the hole.
I put the bolt through the guard upward onto the A-Arm through the drilled hole. After tightening the nut enough to hold the guard somewhat in place. I placed the flat piece of aluminum bar that serves as the inside bracket into place and installed the two bolts to the differential side of the guard. Reaching all of the bolts was easy for both my giant hands and for my sons shorter arms, so no matter your size, they shouldn't be an issue.
Shot of the finished product. Each side took around 20-25 minutes including blocking up the wheels. Depeding on how many small helpers you have, it could take longer. :)
In the front, you will have to drill 3 holes per side. Again I used the guards as templates, drilling up through them to score the surface, then moving it out of the way to finish the holes. A hole has to be drilled in each yellow circle.
Here is the front after completion. It is way better ptotected than it was stock.
On the outsides, the guards caught the plastic covers over the brakes when turning the wheels. It didn't impede the turning of the wheels, but instead of having it happen, you could remove those pieces of plastic, but I cut them with my saw max to clear the new guards.
Overall, I am satisfied with the guards. I feel the less than 2 hours to install all of them was well worth the $100+ savings over the factory ones.
Nice write up!
I can see pics. They are small though. Im on my iphone.
Discussion Starter · #16 ·
Bfair,
Your lift is a thing of beauty.
Discussion Starter · #19 ·
Any concerns with drilling holes in the front A arms?
Make sure you have the guard where you want to mount it then mark the holes. Don't use a super long drill bit and you shouldn't hit anything else when you break thru.
1 - 20 of 51 Posts
