Hi p700 owners, my question is Does the Pioneer 700 M2 non paddle shift 3 speed trans have a wet or dry clutch. After reading engine Cam wipe outs, chains stretching and coming off and Engine failure I am considering adding Rislone Hy-per Lube ZDDP supplement ( Zinc and Phosphorus). adds a coat of protection on cam lobes for cold starts and keeps
engine moving parts lubed at high RPM running. you cannot use it with wet clutches on ATV's and motorcycles with wet clutches, to slippery for wet clutches. hoping the P700 3 speed has a dry clutch.
Moptop
There is no clutch. It’s an automatic transmission so there is a torque converter.
Sent from my iPhone using Tapatalk
Yes it has a torque converter but it also has centrifugal clutches. One clutch is for low the other 2-3. It is a wet clutch system. DO NOT USE.
