1 - 17 of 17 Posts
Venom use to be a decent brand (I've used them in the past) that held up decent. I switched to the Viper winches just for the customer service though. I've had really good luck with that brand as well.
I've got a new 2500lbs winch could I use it and just use a snatch block if I needed would it be strong enough
2500 for an atv. 4000 to 4500 for a utv in my opinion. I had a Viper 4500 with synthetic rope on my Rhino that I got on ebay for about $300. Remember, it's not just the weight of the machine. Add in the weight of the people in it, all the stuff you brought along, and the thick mud you are pulling through.
If you had two snatch blocks, you could turn that 2500# winch into a 7500# winch in pretty short order.
So, yes.......that would be enough....and trump the 4000 and 4500's along the way.
Just for info-
I have a Superwinch Terra 45 (4500lb)
I've used it several times to pull vehicles- (Geo tracker 4wd, Jeep YJ) up hills and out of ditches in loose, wooded trails. Pulling the vehicles up steep hills compresses the front end hard, but the winch seemed to have little issues doing it.
In short, its a beast. I'd say yes, you could get by with a smaller winch, but for the $209 shipped pricetag I found on Amazon, why would you?
I am usually short on cable without snatch blocks so if that's the plan carry extra straps. That tree is always just 5 ft farther.. lol
I went with wire rope. I feared synthetic may freeze and get stiff in very cold conditions.
If you ever went with the good synthetic you would never go back to the wire cable. I have abused my amsteel blue and it is holding up great (3-4 yrs old). The wired cable didn't last me that long so I think it is paying for itself. Working with it is much easier also, none of those wires sticking out to draw blood.
Well Venom has a 3,500lb with syn rope and the mounting bracket for the pioneer for 244 is that a good deal?
That sounds about like the average price for the cheaper winches and mounts.
1 - 17 of 17 Posts
