1 - 8 of 8 Posts
Does anyone know of a wheel spacer manufacturer that makes spacers with the same honda factory lug studs on them? (12mm x 1.50 pitch)
Like alot of us here, I purchased aftermarket wheels and tires and I'm looking to add 1" spacers in the rear to achieve perfect width tracking from front to rear as I have the same size wheels and tires all the way around.
I purchased a high quality pair for Honda Pioneer from "Busted Nut Racing" only to discover that while the bolt patern is a perfect 4/110 Honda fit and bolt up to the machine perfectly, the lug studs on the spacers are 10mmx1.25 pitch.
The problem I'm having is that when I go to bolt up the wheel to the spacer (previously installed on the machine), which is again a perfect Honda 4/110 bolt patern, the lugs are smaller than the factory which means I would have different lugs and studs front to back. While they provide plain OE style looking nuts that will work, I would much rather have the same size matching lug studs and nuts on all four wheels. Especially because I added "ITP" SS212 wheels with matching crome tapered lug nuts.
I found that there are available "similar" aftermarket crome tapered (10mmx1.25) lug nuts, but they are 14mm head vs the much more common 17mm head like the ones I'm trying to match on the front.
Any ideas?
The ones you have are atv which I know whlont bolt right unless you run atv wheels but have you googled some for the big red it has been out a lil longer than the pioneer and has same stud size
Skorp, Those look perfect. In fact I just got off the phone with them and ordered a pair. The guy was really cool and knew what he was talking about. He was going to check the thread pitch and verify 1.5mm before shipping them on Monday. He said he's sold lots of these for Big Red and has never had a customer problem with matching the Honda OE size lug studs and nuts.
Thanks!
Skorp is the man!
Id be a lil faster but internet on the rig kinda slow. Lol I was stuck in the pic but I did make it further in the hole than my rinny did lol . Thanks for the vote
1 - 8 of 8 Posts
