I finally set up the electrical to my winch, however when I did the "al mighty drumroll" and hit the in/out button, nothing happened.
It's my first winch install so maybe I am missing something? Attached is what I did:
Winch is a Warn RT 40 with Honda winch mount kit.
Winch Module: All attached to corresponding colors.
Winch: Yellow to yellow, blue to blue
Battery...now the red wire will be attached to the starter relay switch?(black boot off). The negative is attached to the body. Basically I followed the negitive cable from battery.I believe this is the frame ground bolt?
The winch control harness is installed with the sub harness. All sub harness installed match the color scheme except for the blue wire. It says in the manual to attach the white wire to the white wire, however the only available wire is blue on the sub harness provided. There is no white.
Anyhow, if anyone sees anything I have done wrong or what I can do to see if it isn't faulty, I'm all ears!
Thanks
Thanks
