Well finally got the winch installed although it did take a little tinkering with. I had to cut the roller fairlead mount and bolt it back together to get the cable to come through at the right angle so that it didn't rub on the metal. I also had to cut down the front bumper about 1.5 inches lower to get the fairlead to fit but it all works now and will be painting it all up pretty again come this summer. Just for the record I bought the SuperAtv winch mount plate and the Runva 4500lb winch. Altogether it was an easy install minus some cutting. I also mounted the switch controller beside the driver side door which seems to fit just perfectly as it does not get in the way at all getting in and out and is easily within reach. All in all, for someone with not a ton of technical ability I am pretty pleased with the outcome!
Sports uniform Automotive lighting Automotive tire Vehicle Automotive exterior
Hood Automotive tire Automotive lighting Tire Wheel
Looks good
Nice!! Now we need some pics of it pulling you out!!
