1 - 12 of 12 Posts
Good day,
I am slowly installing my winch (in-between chasing kids and working). I believe the easiest key on power source is going to be off the 12v accessory plug (if i'm wrong please tell me). It has two wires thou and I just want to confirm the "white wire with the black stripe" is the ground wire? Sorry for the dumb question but my circuit tester died on me and I won't be able to replace it for a few days.
Cheers,
Jack
green ground white black stripe is positive
Yes and you're welcome
Flapless Jack you can also order an Accessory Sub Harness #08Z02-HL3-A00 from Honda for $5.95 which replaces the short harness going to the power plug and gives you a switched plug in which allows you just plug in you power wire and not have to alter the factory harness. I am using this harness to activate my power relay to power up my switch panel that I am currently assembling.
Great thanks White park….I'm going to look into that. Does this have multiple inputs or just room for the one accessory? The warn winch key-on power thou is a bare wire so I'm going to have to splice into something anyway instead of just plugging in…..correct me if i'm wrong. I like the idea of not having to splice any wires thou!
you can use a scotchlok to hook that keyed power for the Warn into the accessory power outlet wire. no need to cut and splice.
This harness gives you an extra positive and negative wire with a plug for each using a bullet connector. You replace the original harness that goes to the power plug which is a harness about 8 inches long with the new harness.
I hear yah Moose but if I'm not mistaken those Scotchloks are kinda junkie…..no where near as strong as solder and tape. I know the scotchlok would be much easier and faster I question how it might stand up against the constant vibration and abuse from off road riding. Any thoughts?
Cheers,
Jack
Discussion Starter · #10 ·
Ok..Thanks for the info White. I'll see how long it would take to get one. I have a feeling it would take a few weeks to get this in and I don't have the patients to wait ;)
1 - 12 of 12 Posts
