Fixing to make my own windshield for my bike. Found lexan sheets at Grainger supply (0.236) thick. I think this will make nice install with some removable clamps. Any more suggestions?
although im not the one doing it, clearly, what sandpaper grit range would you suggest using?If you have to cut it, becareful and go slow! And get a fine grit sandpaper and sand all edges, get the "sharpness" off of em!
Goodluck!!
100 grit is goodalthough im not the one doing it, clearly, what sandpaper grit range would you suggest using?
