1 - 12 of 12 Posts
Never seen one of them Rich, I have the lever type works ok but only for certain size rim.
this looks small anuff(4in x4in) to carry in a bag on the ATV-UTV and can be used on the side of the trail to get sand-dirt-bark from a tree out of the bead with just a adjustable wrench ......stock atv tires are a pain in the azz to get the beads broken even with a $4000 tire mechine so for $100+ shipping i cant go wrong (imho)
It looks like it works well and everything. Might be worth the investment. It's $100. That seems like a pretty reasonable price. Does anyone own one or have one on order?
I have the manual tire machine from harbor freight for 50 bucks. its small and you can change out tires for atv without using a mount for it
Zeus .....this is what a buddy (on a different forum ) had to say about this tool .....
( i have one it works awesome i had to work a little on some tires that have been mounted since 99 they was stuck good.. just be careful when i tightened it to the rim i i got it to tight into the bead lock ridge and when it started pushing the tire down it got caught and bent the tool a little but it still works great though.. and ive changed 12 tires so far with it)
not the only one rancher guy. I think this is a good product but I cant use it on executioners. they have a massive rim guard.
I agree, had slow leaks in the bead on both front tires (mud) so used this tool and it worked great! small, strong and it worked!!! best by for on the trail.
That would be nice on the trail!
We have a local garage that will change the tires for $5 bucks so at home I don't need it but sure would be handy in the middle of the woods when there is a problem. Thanks for the info
1 - 12 of 12 Posts
