The filter numbers are still the same as posted above.
Oil filter, 1ea, part#: 15412-HP7-A01
DCT filter, 1ea, part#: 15412-MGS-D21
additional part numbers that you may need.
.....Engine Oil Filter
O-ring for oil filter cover, 1ea, part#: 91301-107-000
Spring inside cover, 1ea, part#: 15414-KF0-000
Bolts for cover, 10mm, 3ea, part#: 95701-06018-00
.....DCT
O-ring for oil filter cover, 1ea, part#: 91302-PA9-003
Spring inside cover, 1ea, part#: 15414-MEB-670
Bolts for cover, 10mm, 2ea, part#: 95701-06018-00
.....Oil Drain plugs.
Drain plugs, 12 mm, 2ea, part#: 90131-896-650
Washer for drain plugs, 2ea, part#: 94109-12000
Sub-Transmission
Drain plug, 17mm, 1ea, part#: 92800-14000
Washer for drain plug, 1ea, part#: 94109-14000
AND AGAIN
WARNING!!!!! CAUTION!!!!! HAZARD!!!!!!
DO NOT follow the torque spec for the filter bolts.
If you do, you can strip the bolts, break the bolts, or strip the hole.
I have read about all of them.
Snug/tight enough that they do not fall out.
