Status
Not open for further replies.
(How To) Dash Menu, Service Reset, Clock Set
1 reading
2.6K views 0 replies 1 participant last post by  Mark from Northern Iowa
#1 ·
Our 1000's dash screen has 6 main screen choices.
It will stay on which ever one you selected last, until you touch the SEL/SET button at the bottom right.
I have mine usually set for coolant temp.
Push SEL/SET
Total engine hours
This menu screen, is also where you must be to set the clock. see below
Push SEL/SET
Miles to next service.
This counts down, until zero, then it will show - and start counting up.
I just serviced yesterday.
Push SEL/SET
Hours to next service.
Push SEL/SET
Total vehicle miles.
Push SEL/SET
trip meter mileage
To reset to zero before a trip:
When on this screen, Push and hold SEL/SET until it resets to zero.
If you need to reset the Service Minder:
1) key off
2) Push and HOLD SEL/SET
3) turn on key
4) When wrench on screen blinks, release SEL/SET button
done
Clock set
Push SEL/SET until you are on Total engine hours screen.
You will see the hour glass next to the time.
1) Push and hold SEL/SET
2) Hold SEL/SET until you reach the time setting you want.
3) Release SEL/SET button
done
Status
You have insufficient privileges to reply here.
